Can I adjust a variable that reads from another variable?
JGoode
I need to edit the variable A but still be able to set it up so that when the object changes it 'A' will revert back to a set value. I can only manage to get 'A' to read from another parameter that I have made but this does not allow 'A' to be edited. Is there a way around this? In my case there are 2 variations of the objects where the width changes so I need A to reset to a default.
ArchiCAD 27
Windows 10
Erwin Edel
Sounds like you'd need a toggle switch for each of the instances.
So if you want A to define the width, that's situation 1. If you want other variables to determine A and this in turn defines the width, that's situation 2.
That way the two instances shouldn't interfere or exclude eachother.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
JGoode
The issue comes when I change one of the widths. Because it scales with B, when I change the width of one then change to a different variation, either the B or one of the width variables will stay the same and not scale correctly until a value is re-entered in. Here is a part of the master script
if (show_text) then
	if GLOB_MODPAR_NAME = "text_width_2" then
		 B=text_width_2*(2/3)
	  endif
	  if GLOB_MODPAR_NAME = "B" then
		 text_width_2=B/(2/3)
	  endif
endif
if (show_text = 0) then
	if GLOB_MODPAR_NAME = "text_width" then
    	B=text_width/0.88
  	endif
     	text_width=B*0.88
  	endif
endif
PARAMETERS A=A, B=B
	A = text_width
endif
if (show_text) then
	A = text_width_2
endif
and here is a part of the 2D mul2 calculation
 if (show_text) then
	mul2 text_width_2/0.075, B/0.05
else
	mul2 text_width/0.0441, B/0.05
endif
ArchiCAD 27
Windows 10
Erwin Edel
Maybe split things up into callable subroutines and run them in order that is needed to keep the variables scaled as needed?
www.leloup.nl
