‎2017-07-19 01:34 PM
‎2017-07-19 01:56 PM
‎2017-07-19 02:13 PM
Erwin wrote:The issue comes when I change one of the widths. Because it scales with B, when I change the width of one then change to a different variation, either the B or one of the width variables will stay the same and not scale correctly until a value is re-entered in. Here is a part of the master script
Sounds like you'd need a toggle switch for each of the instances.
So if you want A to define the width, that's situation 1. If you want other variables to determine A and this in turn defines the width, that's situation 2.
That way the two instances shouldn't interfere or exclude eachother.
if (show_text) then
if GLOB_MODPAR_NAME = "text_width_2" then
B=text_width_2*(2/3)
endif
if GLOB_MODPAR_NAME = "B" then
text_width_2=B/(2/3)
endif
endif
if (show_text = 0) then
if GLOB_MODPAR_NAME = "text_width" then
B=text_width/0.88
endif
text_width=B*0.88
endif
endif
PARAMETERS A=A, B=B
A = text_width
endif
if (show_text) then
A = text_width_2
endif
and here is a part of the 2D mul2 calculation if (show_text) then mul2 text_width_2/0.075, B/0.05 else mul2 text_width/0.0441, B/0.05 endif
‎2017-07-19 04:20 PM
