vfrontiers
Source File Path Display in Title
I place consultant drawings on layouts as part of my full sets of drawings.
I would like to be able to check if the placed drawings are the most current.
I have been just assigning SIMPLE TITLE to them (and place the title OFF the printed area.
MOST of the time, the pdf's come with a DATE so it's easy to tell...
BUT some consultants name them with just the sheet number.
I presumed I could just use the "ac_sourceFilePath" variable, but it will NOT grab the source path nor diplay it.
I was also thinking I could just ASSOCIATE a LABEL to a PDF in the layout window.. but that doesn't work as you can't associate labels in the layouts.
Any advise would be appreciated...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
Ok... nevermind...
I applied the title do a different drawing and it does work... Just did NOT update while I was working on editing the title type...
Duane
Visual Frontiers
AC3.14 - AC29
Lingwisyer
Guru
If the object is not embedded, don't you need to reload the library to get it to update after making code modifications?
