Can I display the Composite separators in a label?
JGoode
I was just wondering if it's possible to display separator lines from a composite in a label similar to the Skin List label?
Thanks
ArchiCAD 27
Windows 10
1 REPLY 1
Erwin Edel
Since there are GDL commands for 3D shapes of the wall variants, I would assume there are parameters that define the separators 'under the hood' of things running. However looking at the script of the composite material label it is not easy to script such a label.
I would consider the trade off between time spent getting this information from the separators v.s. getting it from properties for example or even 'dumb' unlinked information and spending a lot of time scripting this label and potentially having it break with AC version updates.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
