2007-05-21
02:38 PM
2023-05-26
11:35 AM
Rubia Torres
2007-05-22 02:16 PM
alexliz wrote:Where are you seeing internal IDs? Are you doing API work?
Nah, it's alright, I'm convinced...
Karl: I've been using the ID Editor to do just what you say. I still risk, though, having an element with an identical User ID to another element, esp. after a copy procedure, even by another project team member.
Tom: why hex? I thought the INT ID is just numeric strings. They are on mine, at least. In any case, if it's unique and you enter it in the Find field, why do you care what it contains? Just enter the ID, whatever it is.
2007-05-22 03:00 PM
2007-05-22 04:56 PM
2007-05-22 05:40 PM
2007-05-22 05:52 PM
2007-05-22 06:22 PM
2007-05-22 08:47 PM
alexliz wrote:Where is it visible in an Info Box?
..., it's offered in the elements' info boxes, isn't it?
It's even available in the Global Element Parameters in the Set Up List Schemes dialog. Why should GS make it available to the 'normal' user if we're not supposed to use it?.I was under the impression that it was available in the Listing functions for linking with an external database via ODBC, something about 3 people on the planet know how to do. Not exactly a "normal" user task.
