2014-05-28
02:39 PM
2023-05-24
11:44 AM
Rubia Torres
2014-05-28 03:02 PM
Educational (EDU) License
Education versions can be installed only with a serial number.
Registration A serial number can be obtained by registering at https://www.myarchicad.com/. The first step of registration gives you a personal temporary serial number and a download link. The process at this level is completely automatic, so you will receive your serial number and the link immediately after you register. This temporary serial number will give you 30-days usage. At the end of the second step you will receive your personal final serial number that allows you to run ArchiCAD for one year (and can be renewed free of charge after expiration). This part of the process involves an “approval” stage, which will be handled by Graphisoft's local representative.
File Format and Compatibility EDU and commercial project files will have the same file format (.PLN), but EDU files have an irremovable logo at the top right corner. This logo will be present on all printouts. EDU project files can be opened with a commercial version of ArchiCAD, in which case ArchiCAD switches to EDU mode and the logo will be present. Commercial project files can be opened with an EDU version of ArchiCAD. In this case the logo is added, and cannot be removed later. Saving in the EDU version will prevent the file from opening in the Commercial mode. Besides 'Open', no other data exchange (copy, paste, merge, hotlink…) is allowed between EDU and commercial project files.
2014-05-28 07:08 PM
2014-06-02 02:09 PM
2014-06-02 02:22 PM
2014-06-02 02:46 PM
2014-06-02 03:27 PM
2.Since you assigned Wallhole to all the Slabs AC was creating an object that is invisible.
Using the Slab or Roof tool, create another element whose contour matches the outer contour of the desired wall hole or wall niche.
2014-06-02 03:29 PM
2014-06-02 04:53 PM
