Alex_V
Can't open .dwg objects
Hi all,
I am quite new to archicad, but can't seem to open .dwg files. When I choose the .dwg file type I get an error message "the selected file is not a DXF File. Please select a valid DXF file".
If I try to open the object as a .dxf file, I get the message "the selected file is not a file. Please select a valid file".
I tried a few different .dwg files, same error.
The project was created in archicad 26 student version, not sure if that makes a difference.
What am I doing wrong?
Thank you.
1 Solution
Eduardo Rolon
  • Normally DWG files are regular drawings (2D) not objects (3D) so you can use the Drawing Tool to place them.
  • Check that the downloaded file is not corrupted or didn't finish the download. Try opening the file in either a copy of Rhino or SketchUp to see if there is an issue.
  • There used to be a bug that file name size causes problems with imports so maybe renaming the file will let you open it.
Read here:
https://help.graphisoft.com/AC/29/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC29_Help%2F120_Inter...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Go to post
3 Replies 3
Eduardo Rolon
Read here:
AC29 US/INT -> AC08
another Moderator
You could also download and install the free Autodesk DWG Trueview app. Since it is Autodesk's official app, if it can't open it, it is not a valid DWG/DXF file:
https://www.autodesk.com/products/dwg-trueview/overview
Alex_V
Thank you both, opening the files in Sketchup and placing them as drawings was no problem, problem solved, thank you!
