Cant get objects to show textures / materials
i'm having trouble getting the 3rd party downloaded 3d objects to display their materials and or textures in the 3D window. I can get wall textures and archicad object (slabs, stairs) so I know the render engine and graphic cards are ok, but the objects I place all end up colored blue.
Additionally, in the objects selection settings for these 3rd party objects, there is no Model tab for me to select Use Objects Materials.
Any help would be appreciated.
Dan[/img]
5 Replies 5
Looks like is your 3rd party object issue. Try to load them in different AC version to check. Maybe it only work on certain version.
I'd be guessing that the Model section has been turned off in your Work Environment.
Work Environment > Tool Schemes > Tool Settings Dialogue Boxes.
David Maudlin
dankap:
The Material setting can also be added to your Info Box via the Work Environment > Tool Schemes > Info Box > Object Tool > Material, so you can alter this setting without opening the Object's dialog box.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the replies, but unfortunately this does not solve anything.
Do you think it may have something to do with the Pen sets of the object, perhaps they require a separate set which requires loading?
The object materials appear in the settings box but they keep appearing as the default cyan color in the 3D view.
I am using Archicad14 and Archicad 11, and it is the same issue with both versions.
Thanks!
David Maudlin
dankap:
One thing to check is that you have selected "Use Object's Materials" under the Model section.
If that does not work, it seems like ArchiCAD is using the pen color rather than the materials for the object in 3D. This usually indicates a problem with the 3D Script of the object (using the pen color when no material can be read). Changing the pen set will not solve the problem, this object may not have been properly translated for use in ArchiCAD.
David
