How to add text to a 2D objects?
Llian
I mean a text that is 'parametric' to a 2D object saved as library part. I looked through the GDL tutorial but none, unless I miss it, show how to add 'text' to an object. For example, a 2D light fixture with a letter next to it and it can be changed to any letters or text. I tried to duplicate an existing light fixture with the same function but it doesn't work!
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
2 REPLIES 2
The easiest way is to Label the object.
Simply choose Label Object in the settings of the object and depending on which label you have chosen, you can show the ID as text in the floorplan.
Set the default by double clicking the label tool. (set the ID label as standard for the object-tool)
David Maudlin
Llian:
It takes scripting GDL in the 2D Script window, the command is TEXT2, search for it in the GDL Reference Guide. You should be able to find examples in the scripting of objects that have parametric text.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
