2005-02-22
02:15 AM
2023-05-26
11:44 AM
Rubia Torres
2005-05-28 10:39 PM
2005-05-28 10:39 PM
2005-05-28 11:16 PM
2005-05-29 02:58 AM
2006-05-05 08:16 PM
2006-05-05 09:06 PM
2006-05-06 05:55 AM
Jay wrote:You ALWAYS create doors and windows, as well as the panels, on the origin (0,0,0), so that the origin is in the middle of the bottom of the d/w/p, and that the thickness of the d/w/p is in the negative z ("down").
Both door objects were created with the origin at the lower left corner.
2006-05-06 12:57 PM
Djordje wrote:I take it that means 'lying flat on the ground' (in the floor plan)
do NOT use any of the parts of the d/w as the wallhole slab. Do another one, of the exact shape that you want.
2006-05-07 05:24 AM
Thomas wrote:Yes, face down.Djordje wrote:I take it that means 'lying flat on the ground' (in the floor plan)
Thomas wrote:Nope, it has to be a slab - fill is not a 3D element.do NOT use any of the parts of the d/w as the wallhole slab. Do another one, of the exact shape that you want.
A fill will do, won't it?
2006-05-07 04:46 PM
Djordje wrote:Actually I often like to use a fill or polyline and drag it to the 2D script and then to the 3D script for editing. It creates cleaner code for some purposes. It's a bit more advanced technique, but worth knowing.Thomas wrote:Nope, it has to be a slab - fill is not a 3D element.do NOT use any of the parts of the d/w as the wallhole slab. Do another one, of the exact shape that you want.
