ā2022-08-19
09:56 AM
ā2023-05-24
09:42 AM
Rubia Torres
How can I centre a door in the most simple fastest way
Thank you
ā2022-08-19 10:16 AM
Make sure you have guide lines and snap points turned on.
Then ...
The guide lines will disappear after the drag.
Otherwise you can draw a line, activate the snap points, drag the door, then delete the line.
ā2022-08-19 10:53 AM
Thank you
ā2022-08-19 12:40 PM
You can use special snap. I have assigned a keyboard shortcut for this if āsā. You will then be able to activate special snap and depending on the settings you have whether it be half, number of segments of percentage split you will draw a line between two point and the object will snap to the middle or whatever setting you have chosen.
ā2022-08-19 09:48 PM
That is my method as well.
