Change Library Part from 9 to SE9
Is there as simple way to change a library part in an existing drawing from 9 to SE9 while maintaining all the existing criteria? For example I have a bunch of beams (drawn in 9) which I would like replace with the same object in SE9 while maintain all the parameters that were originally entered.
Thanks
Dave
TomWaltz
Thanks
Dave
I don't believe so. Graphisoft was pretty explicit in the SE manual that the two libraries were mostly incompatible with one another.
Tom Waltz
It was really just a hope.........Thanks Tom
