FstID
Change the attributes of Objects
Hello Community,
I am trying to change the attributes of elements, but I need to do it one by one, and whenever I need to place another one with the same attributes, I still need to change it again.
I would like to make the changes in the Bibliothek manager directly and have it permanent that way.
Note* This happened because I changed the pen setup, and I don't want to go back with the old pen set-up.
I know for sure that someone did this before, but I just can't find my way on this one.
All the best!
1 Solution
You mention pens, but this applies to all attributes (fills, lines, surfaces, etc.) if you have modified them in your template.
You have 3 choices that I can see.
1. Go back to the original pen setup that works with the default library.
Or at least just change back the few pens (and other attributes) that the library objects use as default.
This is really the best option if you want to use the default libraries.
2. Set up favourites - you will need one for every object you use.
3. Edit the library objects so the default settings are as you want.
This will require you to extract the .LCF (Library Container File) and then edit each object.
I believe you can batch process with the LP_XMLConverter, but I never have tried as I have found that the objects do not always use the same parameters.
This also means you can never update the library or change to a new version unless you go through the whole process again.
Go to post
3 Replies 3
FstID
Thanks Barry,
The question is how to edit the library. I just don't find a way to edit it.
Every time I edit the library is goes back to the attributes that it had before.
You have to open the objects in the GDL editor, change the default settings, and then re-save them.
But as I said. when ever there is a library update or you change to a new version, you will have to go through and edit the entire library again.
Or don't update your library and continue using the one you have changed - it will effectively be your 'custom' library.
