Changing a Wall and Roof to a window for scheduling ?
Hi I have used a wall and roof to create a butt jointed window.
I'd like to change the ID or type to be a window so it can be included in the schedule.
Is this possible ?
cheers
4 REPLIES 4
David Maudlin
Javadevil:
In the Help files see: Elements of the Virtual Building > Parametric Objects > Graphic Creation of Custom Library Parts and Components > Saving 3D Model Elements as Rectangular Doors and Windows to convert model elements into a window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks, I'll look into that.
This method looks like it turns it into a window that needs to be placed into a wall. I can't see this working for this particular situation.
Isn't there a way I can just tag it as a window ?
I think there is no way out.
Windows are coded to need a wall and not in gdl but in archicad itself so...trick it out, put a wall
