‎2004-01-15 11:32 PM
‎2004-01-20 11:59 PM
‎2017-03-13 10:33 AM
Miquel wrote:+1,
Plus, the lenght of the section line matches the lenght of the section. Sometimes I would like to show a lenght graphically in plan, but with a different lenght (more or less) in the section drawing.
Now we have some parameters to alter the behaviour of the section line (vertical and horizontal limits, distant elements, etc) Why don't add an extent parameter that you can drag in plan?
‎2017-03-13 02:18 PM
‎2017-03-13 08:16 PM
Paul wrote:Might be a nice feature, but "very annoying"? Just throw on a linked section marker and put the "real" marker on a hidden layer. Might take 6 or 7 seconds rather than 4 or 5. You'll get more graphical flexibility in staggered sections, too.
+1,
After all these years, very annoying that it is not yet possible for a section marker at each end to slide inwards along a section line to where it makes most sense graphically in plan, while allowing the extent of section views cut to extend much further
‎2017-03-13 09:54 PM
Richard wrote:There are certainly workarounds for many shortcomings, but that doesn't make passive acceptance the right attitude IMHO; and here the behaviour is positively inconsistent (when switching to a single central marker, the marker can be easily dragged away from the actual section cut line), and it should be easy to remedy, yet it has been left unremedied for many years and ArchiCAD versions - hence the 'annyoing'descriptionPaul wrote:Might be a nice feature, but "very annoying"? Just throw on a linked section marker and put the "real" marker on a hidden layer. Might take 6 or 7 seconds rather than 4 or 5. You'll get more graphical flexibility in staggered sections, too.
+1,
