Children as GDL Objects
I design playgrounds and play areas for schools etc using ArchiCAD.
I have always wanted to add children to my designs/visuals but have never found any good GDL objects of children which I can use.
I would be very grateful if someone could point me in the right direction or offer any advice.
Thanks in advance
Danny
Playground Imagineering
Depends on what kinds of visuals you need, Danny... which then will move this conversation to the Presentation forum in all likelihood...
You can place 2D cutouts, if you just want the outlines of children... by basically making a Morph that traces the outline of a child (or existing child-linework that you find on the internet). Stand these around as needed to appear in any view. Make them an opaque glass material to show them as children ghosts in renderings.
You can place 2D masked images of children by making a special version of the 2D bitmap tree/person object... but these will only look normal in renderings.
A 3D GDL child will look pretty much horrible in any elevation/etc - just as the 3D people do... too many contour lines. Even rendered, they will be polygonal.
Rendering in Artlantis or other software can give smoother results, and Abvent does have children for download.
And, of course, there's the post-production Photoshop insertion of masked images of children...
All depends on what you need to generate, what software you have available, and the time you want to put in / skill set...
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Eduardo Rolon
This
http://www.masterscript.nl/3d-objects/39-silhouette.html
In combination with this
http://vyonyx.com/cutouts/
Might help.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
