Circular Column visualization
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-08-18 09:52 PM
2018-08-18
09:52 PM
Trying to make a good documentation of this view:
Red circles are circular columns.
When I try to export this view and make a pdf file, I get this picture:
All circular columns are segmented with only few faces.
How can I increase faces of these columns to make them more smooth?
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-08-19 02:36 PM
2018-08-19
02:36 PM
Alexander:
If you select the pdf file in the Publisher, click on the Document Options... button, under Document Options select the PDF options, at the bottom of the dialog box are Resolution Options, try setting the Arc resolution to a higher dpi.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-08-19 02:36 PM
2018-08-19
02:36 PM
Alexander:
David
David
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-08-19 09:58 PM
2018-08-19
09:58 PM
David wrote:It works! Thank you!
Alexander:
David
