Rotating of Column Segments
I saw this column design while perusing the web and thought ahh that would be cool to try and model in Archicad.
Segment column, using the circular profile, tapered, then use the tilt option.
The problem I have been stumped with is that in the photo each segment is tilted in different directions, but in Archicad, I can only seem to tilt in one direction.
Any ideas if this can be achieved with the column tool and segments?
I have already tried a complex profile instead of a circular preset, but that too doesn't seem to allow tilting at different angles.
Screenshot 2023-06-01 155803.jpgScreenshot 2023-06-01 154923.jpgScreenshot 2023-06-01 160235.jpg
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
Individual segments can not be rotated, so the end angle for each segment will always be in the same direction.
You would have to stack individual columns.
Each can be set to the opposite angle but they can not be rotated around the reference line.
Thanks @Barry Kelly
I might do a separate wishlist post for the ability to rotate column segments along the reference line.
I don't actually need to above example, but I can imagine in the future this functionality would be useful.
The wish is here ... https://community.graphisoft.com/t5/Wishes/Ability-to-rotate-Column-Segments/td-p/382093
