Clean up lines in section.
Narska
[This is a custom arched window object I made with slabs.
Is there a way to clean up the lines of the arched opening in section so there are not so many of them?
Tomasz Mlynarski
New York based Architect
1 REPLY 1
runxel
Hero
Not without actually editing the script, I guess.
If you want to dig into it: there are "status codes" which define whether you see these lines or not.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
