‎2015-06-19 03:13 PM
‎2015-06-23 06:18 AM
‎2015-06-23 10:01 AM
‎2015-06-23 04:02 PM
‎2015-06-30 11:56 PM
Barry wrote:We use a zone stamp that lets our users select surfaces as parameters to be used in a room finish schedule. The name of the surfaces are requested in the parameter script and then parsed to extract a text designation found in the name that will be displayed on the room finish schedule. We really liked the ease of use. Sounds like we will lose the parsing capability in v20. Wish I knew a way to keep it.
I don't think most users will realise the implications of these changes until they start to use 19 and find their objects may not be working as they once did.
In fact most users will not realise until version 20 when most of these changes will come into effect.
GDL developers will get error messages while scripting in 19 that the end user will not see at all (and objects should work as they have done in the past until version 20 comes along).
So GDL developers it is time to start checking your scripting.
‎2015-07-01 12:36 AM
‎2015-07-01 05:37 AM
Erich wrote:Sure you can use the REQUEST commands in the 2D and 3D scripts and they will work perfectly.
From my reading of the "GDL changes in ArchiCAD 19 v1.1" document, you just can't have the request in the parameter script. It looks like moving it to another scripting environment will allow the requests to continue functioning.
