ā2007-12-07
05:18 AM
ā2023-05-26
11:32 AM
Rubia Torres
ā2007-12-07 05:37 AM
ā2007-12-07 06:34 AM
ā2007-12-07 06:38 AM
ā2007-12-07 08:08 AM
jbArch wrote:Upgrade to AC11.
Any ideas on how to solve this problem?
ā2007-12-10 06:28 PM
ā2007-12-10 06:39 PM
ā2007-12-10 06:50 PM
ā2007-12-10 07:42 PM
ā2007-12-10 08:03 PM
jbArch wrote:There is a "Modify wall" command that gives you a dialog which lets you move the reference line in several ways without moving the wall. I thought you could use it to experiment.
Thomas, I understand what you are saying about the wall length, but I'm not sure what you mean about the reference line location.
I lengthened the wall by a foot on each side of the doors, but I get the same results... see attached jpeg if you are curious. Reference line is on the "back" (non-brick) side of the wall.It is clearly a bug. You should report it through your reseller (if you haven't already).
I've figured out that the problem goes away if I use a single library part. The version shown here is a pair of doors in the center plus a single door on each side, so that's 3 library parts for the bank of doors. It is unlikely I'll get the appearance I want (e.g. fat mullions at the transom) but it is a decent workaround.I'm not sure what you mean by "fat mullions at the transom" but your workaround looks quite good and realistic to me.
