Streamline your workflows and master BIM coordination! Program starts April 28.!
Complex Profiles
Lingwisyer
Guru
Hi all,
How do you go about pulling Complex Profile information then creating an extrusion from said information?
Ling.
9 REPLIES 9
David Maudlin
Ling:
Here is an example part from Graphisoft.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Lingwisyer
Guru
Coolios. So I was looking at the right thing. Just need to figure out how to incorporate it.
Can you pull the profiles height?
Profiles are just a shape, they don't have a height or length.
When you extrude, tube, revolve, etc., the shape, that is when you give it a length or height.
Unless I am misunderstanding what you mean.
Lingwisyer
Guru
_cprism does not define a height. I just have a buffer of nodes and an extrusion length. Is there a way to find the difference between the highest and lowest value of Y within the buffer?
The aim is to shift the profile above zero.
Ling.
CPRISM_ is just the same as a PRISM_, but with materials for top, bottom and side surfaces.
The height can be what ever you want to make it - no need to know the max y value in the profile.
To move the profile above zero just 'ADDz' before the CPRISM_
Lingwisyer
Guru
Ok, my bad wording... I probably should not use the word "height" as I am not talking about the extrusion amount which is defined as height within the operation...
The extrusion is being use parallel to to another face, hence I am wanting a way to compensate for the Profile Origin. So more accurately, I am wanting the distance from the Profile Origin to it's lowest point.
Ling.
Ah, you want to allow for the size of the profile.
I know in the railing tool when you choose a profile, it will tell you the 'height' and width of the profile.
It will be in the code for the profile railing somewhere.
I will see if I can dig it out - unless you beat me to it.
It may well be a request for the profile height and width - not sure yet.
Found it.
reqComp	= REQUEST ("Profile_default_boundingbox",  ac_railProfileID, _xMin, _yMin, _xMax, _yMax)
_profileWidth	= abs(_xMax - _xMin)
_profileHeight	= abs(_yMax - _yMin)
Lingwisyer
Guru
Ah. Have not used a Profiled Rail before so I did not notice that and hence did not think to look there...
Thanks Barry,
Ling.
