Complex Profiles
Lingwisyer
Guru
Hi all,
How do you go about pulling Complex Profile information then creating an extrusion from said information?
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
9 REPLIES 9
David Maudlin
Ling:
Here is an example part from Graphisoft.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Lingwisyer
Guru
Coolios. So I was looking at the right thing. Just need to figure out how to incorporate it.
Can you pull the profiles height?
Profiles are just a shape, they don't have a height or length.
When you extrude, tube, revolve, etc., the shape, that is when you give it a length or height.
Unless I am misunderstanding what you mean.
Lingwisyer
Guru
_cprism does not define a height. I just have a buffer of nodes and an extrusion length. Is there a way to find the difference between the highest and lowest value of Y within the buffer?
The aim is to shift the profile above zero.
Ling.
CPRISM_ is just the same as a PRISM_, but with materials for top, bottom and side surfaces.
The height can be what ever you want to make it - no need to know the max y value in the profile.
To move the profile above zero just 'ADDz' before the CPRISM_
Lingwisyer
Guru
Ok, my bad wording... I probably should not use the word "height" as I am not talking about the extrusion amount which is defined as height within the operation...
The extrusion is being use parallel to to another face, hence I am wanting a way to compensate for the Profile Origin. So more accurately, I am wanting the distance from the Profile Origin to it's lowest point.
Ling.
Ah, you want to allow for the size of the profile.
I know in the railing tool when you choose a profile, it will tell you the 'height' and width of the profile.
It will be in the code for the profile railing somewhere.
I will see if I can dig it out - unless you beat me to it.
It may well be a request for the profile height and width - not sure yet.
Found it.
reqComp	= REQUEST ("Profile_default_boundingbox",  ac_railProfileID, _xMin, _yMin, _xMax, _yMax)
_profileWidth	= abs(_xMax - _xMin)
_profileHeight	= abs(_yMax - _yMin)
Lingwisyer
Guru
Ah. Have not used a Profiled Rail before so I did not notice that and hence did not think to look there...
Thanks Barry,
Ling.
