Complex poly math question.
Hey all,
I have a fairly complex math question (or at least for me). In a gdl object i want to draw a polygon that has 2 sides made from a curve and 2 sides a straight line. This is easy enough but i also want to fillet where they join, see sketch.
Does anyone know the how to work out the formula for this, i believe the formula lies in analytical geometry but is a bit beyond me.
P.S. I realise 2 lines can be filleted using status codes using poly_b but i need to know the start, end and centre points of the fillet when a straight line and curve intersect to use this.
Thanks for any help
11 Replies 11
LiHigh wrote:
You are right!
The Fix:
r2 = r1 + d
u = ASN(f/(r2-f))
w = ASN(f/(r1+f))
Thanks again guys for the solution.
LiHigh, do you mind if i post this and illustration on www.gdldeveloper.com aswell. I think others will find this very useful.
LiHigh
No, I don't mind.
Howard Phua
Win 10, Archicad 19 INT
