4 weeks ago
Hello , Why the door dont cut one of the skins of a complex profile wall?
Operating system used: Mac Intel-based
4 weeks ago
Check this thread out, it might have the answer you’re looking for:
4 weeks ago
i think there is no solution to my question in that thread
4 weeks ago
Did you check the position of the Opening References in your complex profile? I suspected (hence the link) that one of the references is located on the outside face of one skin but not on the other, and bc of that, the door doesn’t cut through the latter. If that were the case, all you’d have to do is move one of the opening references to the correct position. But maybe I’m wrong:)
4 weeks ago
i have to check it in the complex profile?
4 weeks ago
If you are referring to the green lines going through the door space, is your door sill above the base of the wall?
That is normal to see the wall sides in that case.
3 weeks ago
there are fills also that the door dont cut in the wall socket
