‎2006-08-29 05:39 PM
‎2006-08-29 08:52 PM
‎2006-08-29 09:54 PM
‎2006-08-30 12:03 AM
F. wrote:Hi Frank,
What's the exact error message?
Can you post the code passage?
Try this:
result_113 = sweepgroup ("group_112", -0.001732050807569, 0.001, 0)
The first version of the command has the same syntax. Maybe this works. Probably the difference is internal as RULED and RULED{2}.
‎2006-08-30 12:05 PM
Peter wrote:Worked of course in AC9...ahhhhhrg...
Hello Mats,
It looks like the auto-script mechanism has shot itself in the foot.
It's interesting that the "sweepgroup{2}" command is not
mentioned in the AC 10 GDL reference manual.
You might try saving the project that contain the elements
you are trying to auto-script into AC 9 format, opening the
project in AC 9, and trying the auto-script in that version ?
Peter Devlin
‎2006-08-30 12:19 PM
‎2006-08-30 01:20 PM
F. wrote:I don't have the time to look deeper into this. I will do the stuff in AC9 in the future. I spent several hours of dearly precious night time to fix this...so right now I don't want to GDL anything more...until Nottingham next week....
Have you compared both scripts? v10 <> v9? Whats the difference? Works the v9 scripted version in AC10?
‎2006-08-30 03:55 PM
‎2006-08-30 09:09 PM
‎2006-08-31 09:43 AM
Peter wrote:OKi, the AC9 autoscripted object works in AC10...
Hello Mats,
I had made an assumption that once the object was successfully
auto-scripted in AC 9 it would work in AC 10.
I understand that you don't want to compare the two scripts
but could you answer Frank's other question.
Does the AC 9 auto-scripted object work in AC 10.
Thank you,
Peter Devlin
