Contour Lines On Basic 3D Elements
Hi All,
Is there any way you can turn off the contour lines on basic 3D elements (such as brick, block, cylind, etc)
Is there some global variable I can change before the block command, which controls status codes?
I know it is easy to change the status code in more advanced 3D elements (such as cprism, sprism,etc)
Thanks,
Tom
Erich
Nope, that's why the more advanced options exist.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Ok Thanks,
Just wanted to check before I recode. Just means I shouldn't be lazy in the future
