Vertices of 3D objects
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-12-04 07:35 PM
‎2013-12-04
07:35 PM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-04 09:45 PM
‎2013-12-04
09:45 PM
In the wire frame view, you can't. In other views (Open GL or Hidden line) you can depending on how the object in question is scripted. Which object do you want to revise?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-05 12:02 AM
‎2013-12-05
12:02 AM
I think this object is not a GDL boject from the ArchiCAD Library. Rather, it was imported from a 3DS, DWG or SketchUp file, hence the triangulation.
You could convert the object to a Morph, set the edges you don't want to see to Hidden for the Morph, then resave it as a GDL Object. That could get you closer to the state you want it to be in.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-05 11:37 AM
‎2013-12-05
11:37 AM
Thanks Erich and laszlonagy the answers. I imported a file from Revit. The converted objects for ArchiCAD GDL. When you convert a GDL Morph object to the file is heavy, with many vertices. No way to lighten Morph without spoiling the objects (warp)?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-05 02:11 PM
‎2013-12-05
02:11 PM
judsonarq wrote:You can try:
1. Suspend Groups
2. Select part of Morph that is "heavy"
3. Modify Segmentation... > Fewer Segments
This will decrease the number of faces, but also make the form rougher.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-05 02:33 PM
‎2013-12-05
02:33 PM
If You finish Morphing, I would suggest save thee result back to object, as the objects are much faster than the Morphs in general.
Best regards,
Piotr
Best regards,
Piotr
