Copy Windows
How do I copy a window from one wall to another? When I use the Ctrl+Drag option, it only lets me copy with the same wall as the window being copied.
Thanks.
17 Replies 17
Stephen Dolbee
You can't. You can alt-click the window you want (to make sure it is the same window), and then just click it into place in the other wall.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
This question was asked back in 2003. I would like to ask it again in hope that this facility has been improved in the 13 years since.
Specifically, how can I copy all the windows on one story, to another story?
Thanks for any help.
Eduardo Rolon
as it was done in 2003 and since, either:
• you copy the wall with the windows from one story to another in floor plan
• copy the windows in Elevation
• copy the windows in 3D
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
• copy the windows in Elevation**
• copy the windows in 3D**
** as long as the original wall and destination wall are in the same plane (i think)
Eduardo Rolon
Yes, or if it is one wall spanning multiple stories.
AC29 US/INT -> AC08
It is not so much just the walls in the same plane but the reference lines must be in the same plane.
And the walls do not need to touch - you can drag copies in plan, elevation or 3D.
Hi just adding a little bit, I learn somethings in the Jared (Shoegnome) Archicad Tip # 8 in youtube, you can watch that video, is interesting.
PD: sorry, can't put the link, cause I'm in a office with a Internet Filter that doesn't let me get to youtube.
Here is the link to the clip:
https://www.youtube.com/watch?v=wcIKGsrQ_s0
The clip talks about moving Windows horizontally from one Wall to another, but it works the same way in vertical situations.
Let me guess , it's 2020 and it's still impossible to copy door or window from one wall to another if another wall is not parallel to first but stays aside . right ?
