We value your input!
Corner Window AC10
If there's a way in AC10 to make a corner window without frame at the corner?
Yamil,
You posted this question several weeks ago and were
given an answer at that time.
Perhaps you did not like the answer.
Please see this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?p=69906&highlight=corner+window#69906
Peter Devlin
I apologize for did not answer before, you're right. The project was in hold for the client so I did not try to do it again. I'm half way of your suggestion with the empty corner window. Thank you so much for your help.
Andy Thomson
Storefront and Curtain Wall windows and objects will do this also. You can set the frames anyway you like. So will DWB 35 parts (door&windowbuilder - cadimage). The former will also handle butt-glazed conditions.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
