Corner windows with posts
KeesW
Can someone tell me how to create a corner window with posts set back from the face of the wall. Usual corner windows leave the corner walls in place.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Erwin Edel
Depending on which library you are using for the windows, there should be an option to turn into corner window.
I have Dutch localisation, so it is a bit hard to describe for a different library, but the parts are just translated from the Graphisoft library, so it would work the same on different versions of the Graphisoft library.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
The attached image is one of the standard GS windows.
Make the corner setting and just move the window into the corner.
If you use the corner window tool you will be stuck with both windows being exactly the same.
Place them as separate windows and adjust the corner settings and they can be different windows and sizes.
