Learn more
Craftsman Column GDL
Does anyone know where I can get a craftsman column GDL? I'm mainly interested in the squared tapered column, either with or without a base.
12 Replies 12
Dwight
I had no luck last year for a pseudo historic renovation and made my own with the complex profile.
Based, sort-of, in these:
McCoy Millwork
Dwight Atkinson
Erika Epstein
objectsonline.com
did you check the gdl depository here on the first page of ACtalk?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Rick Thompson
I don't do GDL, but I needed a versatile column, so Frank Lazar made one for me. It is here... http://www.objectsonline.com/product_info.php?products_id=1545&osCsid=b041679f68644e544f73703b4725ed...
The image doesn't seem to go through the options unless you click on the little side image, but you can change just about everything.. taper top and bottom.. add moldings... etc.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Thanks for the help everyone. I may end up purchasing your object down the road, Rick. But, I actually spent a few hours and made my own using the polygon prism shape w/ some added trim.
Rick Thompson
While I don't make anything off it ... for future reference it is well worth $18 as for time saved:) It is quite flexible.
Rick Thompson
Mac Sonoma AC 26
That was fun, wasn't it ?
i would like to get a hold of this object, but the link just takes me to artlantis home page.
David Maudlin
thepsyntyst:
Abvent bought Objects OnLine, then later closed the shop. You might try contacting Ferenc or maybe Rick will post back with some information.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
gpowless
Whenever I get stuck on modelling an element, I first think about how it will be constructed.
In the case of craftsman details, considered that they are constructed of wood. So I have built those columns using complex wall profiles. Create 1 profile & surround the column with it. Very simple.
Architecture must represent the real world. While we can push boundaries in design the bottom line is that it has to be constructed to come to fruition.
Intel i7-6700@3.4GHz 16g
