Creating GDL Objects
I created a custom brace for a canopy overhang, I would like to rotate it about its x-axis, what parameters do I now need to include?
I would appreciate any feedback.
4 REPLIES 4
TomWaltz
Before I answer too detailed or not detailed enough.... how much GDL experience do you have?
Tom Waltz
Dwight
The answer to the rotation problem is on page 28 of the GDL Reference Manual.
If you want to learn GDL, see the GDL Cookbook:
http://www.nottingham.ac.uk/sbe/cookbook/gdl_cookbook/index.html
Dwight Atkinson
In 3DScript:
ROTX Angle
where Angle is a number. For instance ROTX 90
Dwight
Of course it is not that simple.
That command needs to be near the beginning of the script to impose the rotation transformation before the code for the shape is executed.
Dwight Atkinson
