Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
Of course it is not that simple.
That command needs to be near the beginning of the script to impose the rotation transformation before the code for the shape is executed.
