2008-04-28 02:32 PM
2008-04-28 03:29 PM
2008-04-28 06:38 PM
Rolday wrote:OBJECTiVE will provide a quick and easy solution:
I'm having a few probs with creating mouldings. I have created some by using line tool to create the section and magic wand slab to it, then saving 3D as object.
However the problem is that i want to mitre the ends to form a return - i have tried to look at the scripts for existing mouldings but finding it tricky.
I need to create some to win a contract - what would be a quick way to overcome my mitre problem.
2008-04-29 07:28 PM
2008-04-29 11:33 PM
2008-05-03 03:58 PM
Dwight wrote:Quite agreed!
Djordje: with all due respect, the Profiler tool is obsolete for generating conventional mouldings. Use of complex profiles in a wall element is superior because:
- instant edit/swap of profile once the initial shape is placed.
- multi-color/materials in one extrusion.
- with self-healing/auto-join at any angle, who needs a mitre?
- magic-wanding of moulding to room perimeters !!!!!
- grouping/ganging mouldings, wainscotting and baseboard with multi-surface walls makes trimming-up fancypants rooms easier - or just gang up the trim bits and leave the base wall separate.
2008-05-04 02:22 PM
Djordje wrote:Hi Djordje - I think you're still missing an important point Dwight was making - 'Profiler' is a redundant tool. It never was a very good tool anyway - almost no editing capability or 3D freedom - and Complex Profiles replaced almost everything it did.Dwight wrote:The topic was creating these parts as objects. However wonderful Objective is, one should first make very sure that what needs to be done cannot be done out of the box.
2008-05-06 07:05 PM
2008-05-09 03:09 AM
Djordje wrote:Ralph:
No, Ralph, I am not missing the points.
You are missing mine - that people should first be very sure that they can't do what they need to out of the box, before they buy your excellent product. Or any other product, for that matter.
That was the only point, and I am not going to elaborate, giving you another advertizing opportunity.
2008-05-10 04:53 AM
