We value your input!
Curved Roof & Gutter
henrysaxby
Hi Archicad Community,
 I'm working on a CAD model of an existing building that has a lot of curves in the walls, and warped roofs. As the project will involve extending the building with more of the same, I need to create the building as it exists today. The issue I'm having is creating accurate guttering:
 I've created a complex profile and can easily draw the gutter in. Using the magic wand tool, I can then create curved guttering. The issue then becomes incorporating the fall into the gutter. Once the gutter is curved, it can't be rotated on a vertical plane. I've then converted the curved beam to a morph which allows the rotation (this is clunky at best). This works to a limited extent. I can get fall, but it doesn't match the curve of the roof well. Also, once converted to a morph, the intersecting joins disappear.
 I tried my luck using the magic wand in the 3D window (thinking it may clip to the roof edge): this gives me the curve but again leaves the vertical aspect out.
 Does anyone know of a work-around? Does anyone have any suggestions?
 Thanks in advance!
1 REPLY 1
Hmooslechner
2 solutions:
Apply Your profile to a rail without anything than the profile - rails ran follwow hight-adjustments.
or
simply draw  a profile as Morph and "morph-SEO-add it"  to a 3D-Morph-line-path and follow it.
