ā2009-04-22 09:23 AM
ā2009-04-24 04:35 AM
ā2009-04-24 04:36 AM
ā2009-04-24 10:20 AM
ā2009-04-24 09:12 PM
Karl wrote:Karl, do you mean delta testers, for UI re-looking?
...and here is the INT ramp profile tab UI, vs the ramp profile UI which is at the bottom of the single US panel in the previous screenshot. Here, again, look at the UI's material entry field. Looks like a heck of a lot of blank screen space to the right so that the button could be wide enough to read off the material name without clicking on it! Drives me crazy.
ā2009-07-29 05:54 PM
ā2009-07-30 05:53 PM
ā2009-08-01 10:56 PM
David wrote:Thanx david, but actually Ascent was turned off, and actually you can tell its a bug looking at the parameters where it mentions the slop angle ( grayed one ) , the value is negative!
whatever:
I just played with this object a little bit, and found the problem you described, then set the Ascent Length to a smaller, appropriate length, and the 2D symbol displayed correctly. Also, the 3D model of the part was irrational with the too long Ascent Length. You may need to make sure that the parameters are set to appropriate values for such a short ramp.
David
ā2009-08-02 04:40 PM
