‎2020-07-30 10:43 PM
‎2020-07-31 03:19 AM
‎2020-07-31 09:48 AM
‎2020-07-31 10:03 AM
‎2020-07-31 10:56 AM
‎2020-08-02 12:15 AM
‎2020-08-12 10:26 PM
Dalius wrote:Dear Dalius,
Barry,
In this case, as Lingwisyer rightly noticed, these settings (length, height, depth) should be available in the Knob settings. They are now "hidden" in the All Parameters section.
On the other hand, there is no unified logic here. If you save your model as a Handle instead of a Knob and insert it into the Door, it will automatically be the correct size (without the ability to edit).
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-12-09 12:40 PM
‎2020-12-09 04:04 PM
‎2020-12-10 11:22 AM
DGSketcher wrote:Yes but that's not accepted
Could you select "None" for the door handle and include a handle in the custom door leaf model to get around the problem?
