2009-07-06
10:45 AM
2023-05-24
11:57 AM
Rubia Torres
2009-07-06 01:24 PM
2009-07-06 02:55 PM
2009-07-07 07:57 AM
David wrote:Hi David, thanks for your help.
....... the Section-Elevation Marker Macro, so this is the code you should be looking at. Changing the anchor point should not be too hard, making it behave as the part is rotated and/or mirrored will be more challenging...
2009-07-07 01:19 PM
NandoMogollon wrote:Nando, you will need to add an item to your menu to enable the selection of a Sub Type.
I can't find the "Section-Elevation Marker Macro".gsm or the script anywhere.../...
2009-07-07 02:34 PM
Rod wrote:Thanks Rod.
Not sure you will achieve what you want, but now you know how to find sub types.
2009-07-07 05:55 PM
NandoMogollon wrote:A macro can also be opened by selecting the macro name in the Call statement and using the Open Object... menu command or shortcut key.
2009-07-08 01:28 AM
David wrote:Thanks David, something new learned.
/....A macro can also be opened by selecting the
2009-07-08 01:58 PM
2009-07-08 02:05 PM
