‎2015-06-19
12:31 AM
‎2023-05-24
11:41 AM
Rubia Torres
‎2015-06-19 01:13 AM
‎2015-06-19 01:21 AM
laszlonagy wrote:
I think your A and B parameters are very much out of proportion. ARCHICAD resizes the 2D Symbol you have drawn to be the size defined by the A and B parameters. They should be set to similar default values in the Library Editor.
Another way of creating a new Section Marker is to open an existing one, save it under a new name and modify that. Might be better way of doing it because an existing one is already working, already has all its parameters, etc.
‎2015-06-19 11:08 AM
‎2015-06-19 03:33 PM
laszlonagy wrote:
The Built-in Section Marker doesn't have a 2D Symbol and it doesn't have a 2D Script. But it has a Master Script which is executed at the beginning of every other script, including the 2D Script.
Anyway, I created a simple Section Marker like yours based on the default Section Marker.
It responds to the size settings changes made in the Marker Height field of the Dialog. See attached file.
You will see that I have drawn a 2D Symbol, then also created a simple 2D Script which set the scaling properly, then places the 2D Symbol.
‎2015-06-19 03:46 PM
‎2015-06-19 04:00 PM
‎2015-06-19 04:03 PM
‎2015-06-19 04:38 PM
‎2015-06-19 04:44 PM
