Custom door panel option does not work!
i'm trying to work with Archicad 14 doors and use a custom door panel, but It will not let me type anything into the parameter field when I select custom panel. I'm realy getting tired of broken library parts. Does any one know an easy fix?
Also The storefront door panel styles will allow you to change the stile witdth of the sides, but not the bottom rail.
Thanks
5 Replies 5
You cannot type in the data field.
Rather, you select from available custom panels.
Until you have created and saved a custom panel, nothing will show up as an option there.
This is actually a huge improvement. In older versions, you had to type the name of the panel, and if you typed it wrong, nothing showed up but an error message. Now, you basically get a menu of available panels and cannot go wrong.
How do you save the custom profile so it shows up as a custom door panel in the door. I have created the panel as a library part that is loaded, but it does not show up.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Did you save the panel as an object or a custom component? You need to draw/model your panel then go to File>Libraries & Objects>Save Custom Component... Then select Custom Door Leaf, click Choose and then name and save the panel. Now open the door tool and under "Door Panel" either in parameters or settings box, select the Custom Door Panel at which point a new flyout or option will appear to select from a list of saved custom panels.
Did you do that, or something different?
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thanks that worked. I wasn't using the save as component. I wish the documentation on this stuff was better.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Check out Chapter 4 of the ArchiCAD Tutorials:Building Objects Creation interactive training guide. It details the whole process.
http://www.graphisoft.com/education/training_guides/?version=12&module=GDL&lang=en
For ArchiCAD 12 and higher.
HTH
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
