Custom handle / Component Bug in Doors - AC11 & 12INT
AC11 & 12 INT - Latest libraries.
Can anyone else confirm that specifying a custom handle on a plain solid door (Style 1) produces a "LABEL 990 not found" error even using default settings? All other door styles seem to work.
This affects all wood internal and entrance doors and also sliding doors.
If it isn't just my machine, then I'm surprised this hasn't been spotted before - it exists in both 11 & 12 with all their multiple library updates.
Many thanks!
5 Replies 5
Sorry to be a bore, but can anyone confirm or deny the problem exists in the INT library?
Bumping your topic for someone with INT to respond...
(No problem with the US library on this one; I don't have INT installed.)
Hi Peter,
I can confirm the "LABEL 990 not found" error on both 11 and 12 INT libraries (with the latest updates).
Hope it will be fixed in the next update.
Adrian Tudoreanu
Thanks guys, I'm not going mad then!
Lets hope they fix it quickly too! There seem to be too many 'bugs' in the AC12 library at the moment.
GS confirmed the bug and is working on it.
Thanks for reporting it.
