Stefan Videnov
Custom objects become invalid when downgraded from AC29 to 27
Hallo,
I've made a few custom objects with some relatively basic script. I need to access these objects with projects which are astill on archicad 27.
When I save our 29 template file to 28 and then 27 the objects unfortunately stop working. I do get the following error:
I haven't put anything into the "Forward migration" and "Background migration" fields, and tbh. I don't know how they are used.
Could you help me with moving the objects from 29 to 27?
Thank you!
3 Solutions
CosminF
maybe you'd want to look into this tool:
https://community.graphisoft.com/t5/GDL/Free-open-source-tool-downgrade-GDL-objects-gsm-to-older/m-p...
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
Do those objects call any macros from the 29 library?
If so that would be a possible cause for errors.
If they are "simple" objects with no macro calls, then I would have thought that they would have saved back.
But maybe there is an actual block that prevents 28 objects being saved back to 27.
Otherwise it might be possible to use the LP_XMLConverter - which sounds like the link CosminF gave does something similar.
Absolute worst case scenario, you could create a new object in 27 and re-create the parameters, and then copy and paste the script text.
Note that this will create a new object with a new GUID, so they will work in 27 and up into 28 and 29 but they will not be the same object as those you already have in 28 and 29.
They will be regarded as 2 separate objects.
I still create all of my objects in 25 so they will be compatible in all versions 25+.
Go to post
Hello Stefan, if you place the objects in the embedded project library and save the file into a previous format, the objects are downgraded automatically without needing to use the xml converter.
www.graphisoft.com/en-gb/partner-solutions/airc-digital-openbim-services/ co-founder /Operations Director /BIM Lead @ www.airc.digital ltd ™
M Architecture & Urbanism
Archicad 29 ARM, MacBook Pro M3 Max 128Gb, macOS Tahoe.
Go to post
6 Replies 6
CosminF
Stefan Videnov
Thank you for the advice guys, it worked.
The objects were very simple, parametric 2D shapes. No macro calls .
Lingwisyer
Guru
I guess we were all making the assumption that they were in the embedded library, but indeed, it was never explicitly stated... the objects need to be contained within the file when saved back to downgrade them as well.
Stefan Videnov
Hi Jaime,
That's very sharp!
Now that I think about it, you're right, the objects were in a linked container library. Obviously setting the version bank wont changed the files in the container.
