2011-01-31 11:36 AM - last edited on 2023-05-24 12:37 PM by Rubia Torres
2011-01-31 11:58 AM
2011-01-31 02:07 PM
2011-01-31 02:08 PM
jonyyybe wrote:Are you sure you saved the Component into a loaded library?
When i make an custom panel with File->Libraries and Objects->save Custom Compenent-> Custom Panel Door or Custom Window Panel. It's makes with no problem, but when i go to door-window properties to custom panel and i give the option to custom panel, in 3d it's apear empty, no customize.
jonyyybe wrote:Each piece of roof can only have one slope (plane). For two slopes (planes) you need to create two roofs then join them.
Can I give to a one of sheet roof (one sheet, not the all roof, just at one sheet of roof) two slopes (inclinations) in the same time. I know I can give one slope but two slopes in the same time!?
2011-01-31 02:40 PM
David wrote:You may be right, i will se if it's in the loaded library.jonyyybe wrote:Are you sure you saved the Component into a loaded library?
2011-02-01 03:23 AM
2011-02-01 05:11 AM
2011-02-01 08:28 AM
2011-02-01 08:56 AM
jonyyybe wrote:As per the original image it is one roof that appears to slope in two directions.
Barry,
Sounds like you are trying to make a roof that slopes from back to front with a inclination and side to opposite side slopes with another inclination at the same time.
I didn't understand what did you said there.
2011-02-12 12:21 PM
