‎2017-10-04 09:27 AM
‎2017-10-04 10:15 AM
‎2017-10-04 10:44 AM
‎2017-12-19 03:56 PM
Barry wrote:Hi! After modelling all the other things in for the fitting, how do you call in the IES Light?
Just had a quick look and there is an IES Light object that appears to be just the light itself.
So model the fitting as above - i.e. model the base and move the local origin and add ROT commands ready for the moving part of the lamp.
Then when it comes to the lamp part you would model that and then move to where you want the light source to sit in the lamp part (i.e. move the local origin again) and then CALL in the IES Light object (feeding it whatever parameters you want to control).
DEL all the moves and rotations.
‎2017-12-19 11:28 PM
