Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Find the perfect object, manage libraries, create custom objects
Customizing Elevator Standard 11
Hello, I need to make a freight elevator. I love the elevator standard 11, I just want to make its dimensions a little larger so as to pass for a freight elevator, but the areas are grayed out.
There's another elevator here that's customizable, but it's one of those weird semi-circular glass ones and I'd rather not use that.
Help?
Thanks
3 REPLIES 3
David Maudlin
tdellaqu:
In the Story and Elevator Door Position Settings pane, click the 2D Representation & Help button, then change the Passenger Capacity pop up to Custom.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Wow
that's amazing
Thanks so much!
Elevator position should be freely......................But i have not any idea how to customize elevator standered 11. If you have any idea please you can share with me. Thanks
