D1 Storefront missing frame
Can someone verify that when setting the transom height of the D1 Storefront 3 door to 0 that the perimeter frame disappears? The only way to workaround this that I've found is to set the transom to a small value. Not great, but it will get the job done until a fix is posted.
4 Replies 4
Djordje
Take a look at http://archicad-talk.graphisoft.com/viewtopic.php?p=23045#23045
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Sounds like a similar problem, but with a different library part. The problem is if I turn off the transom by setting the height to zero the entire sidelight frame disappears
Yes, I can verify that this happens with D1 Storefront 3. In addition to the frame being gone, the transom is wider then the door and I can't remove a center horizontal mullion in the transom without the transom glass disappearing in addition to its frame.
For what its worth, I note on your jpg that we are both using this library part with one sidelight only.
I haven't posted in years, am now using ArchiCAD 9 on Mac OSX. Disregard my previous signature
