‎2013-10-07 02:01 AM
‎2013-11-19 09:53 PM
‎2013-11-19 10:01 PM
‎2013-11-19 10:07 PM
‎2013-11-19 11:36 PM
‎2013-11-20 03:05 AM
‎2013-11-20 03:31 AM
‎2013-11-26 12:41 AM
laszlonagy wrote:Arcadia wrote:I would be using this method if I needed to.
Some like having details externally that are linked but this creates problems as if you update your external std it will update in your project as well which can cause inconsistencies especially if you need to customize something. Better to have all details within your project file.
I think the concern you raised can be handled relatively easy:
Go to the Drawing Manager, select all those external source details and click the Break Link button.
Now all those Drawing will become embedded into the Project File and you don't have to worry about them changing.
If you now go to their settings Dialogs you will see that the Update Status field says "Embedded", and the Store Drawing in the Project File became checked if it was not checked before.
‎2013-11-27 12:35 PM
Maysum wrote:In the Drawing Manager you can always select any Drawing in the list and use the Link Drawing to button to re-link it to any internal view or external source.laszlonagy wrote:Arcadia wrote:I would be using this method if I needed to.
Those files you have embedded, what happens if you decide to update it, what would you do? an how would you do it?
