Difficulty getting multiple levels to show correctly
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2008-04-18
03:31 PM
ā2023-05-26
12:21 PM
Rubia Torres
ā2008-04-18
03:31 PM
If the cut plane for the floor is set "normally" (approx. 4' A.F.F.) relative to the majority of the floor, allowing those windows and doors to show properly, then the windows and doors in walls on other levels don't because the cut plane doesn't go through them.
Is there a way to have multiple cut planes for one story? Is there another solution?
Thanks
Bill
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-04-18 04:33 PM
ā2008-04-18
04:33 PM
Bill wrote:No.
Bill wrote:Yes -- create multiple Views of this Story, each with its own FPCP, then crop and assemble the Drawings to appear as a single plan on the Layout.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-04-18 11:31 PM
ā2008-04-18
11:31 PM
I've never done it, but I guess it's also feasible that you could assign particular walls, windows, doors, etc Symbolic displays (so they ignore the cut plane) and leave the others as is (so they are affected by the cut plane).
Guess it depends on the siutation, but as I said, I've never tried it.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-04-19 01:05 AM
ā2008-04-19
01:05 AM
Bill:
I have done the opposite of what Link is suggesting: I have most of the walls (and doors and windows) set to Symbolic, then taken a few walls (and doors and windows) and used the FPCP for special circumstances (for example a 2 story house that has an entry at mid level). From your brief description, you might want to set everything to Symbolic, then use the FPCP for just a few elements.
My 2 cents (and you can search this forum for other opinions/uses of the FPCP).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC28 USA ā¢ Mac mini M4 Pro OSX15 | 64 gb ram ā¢ MacBook Pro M3 Pro | 36 gb ram OSX14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-04-20 11:45 AM
ā2008-04-20
11:45 AM
Laura wrote:Laura's solution is by far the best - since it worksBill wrote:Yes -- create multiple Views of this Story, each with its own FPCP, then crop and assemble the Drawings to appear as a single plan on the Layout.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-04-20 10:11 PM
ā2008-04-20
10:11 PM
What?!
This is hardly a workaround. The Symbolic Cut is provided specifically so that elements CAN ignore the cut plane. If anything, Laura's method (while still good) is more of a workaround. If the situation was relatively simple changing the settings of some elements, is far simpler than aligning and overlapping multiple drawings on a layout.
Sheesh,
Link.
Sheesh,
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-04-20 11:36 PM
ā2008-04-20
11:36 PM
Link wrote:Link, I find that depends.
In a situation when I need to create several views of the same area, to have set some elemets as symbolic to work in one of those might create issues in others. While Laura's being completely consistent, with a FCP at a fixed distance from each floor, won't. It's not less work if you want one quick solution, but might save work later in a complex project. I think you need to consider the specific situation.
YMMV.
