Disabling contour lines in Rectangular Window Opening
I have simple question. Is it possible to disable contour lines on object from standard library called "Rectangular Window Opening 20". The lines I want to turn off are shown on below pictures. Thing is that casing from this window have the same material as the connected wall but lines are still visible. Is there any solution for that?
1 REPLY 1
matjashka
Kostek,
You won't be able to hide the contour of the window frame like you're attempting to. If your intention is to hide the window frame from either side, maybe try playing with reveal settings? Sometimes setting widths to zero help with presentation in plan or elevation scale, and then you just resolve the actual condition in a 2d detail.
Matt Krol [LinkedIn]
BHMS Architects and Planners, Chicago
AC 10 ... 26 USA
